Long press on it, press on the i button, block notification
Oh i guess it's one of those notifications that they don't want you removing. Sorry i don't know of an easy fix
Because they want you to spend money on data. Lol. It's your carrier. If I turn off mobile data, I get no notification. So your carrier inserted that feature so you keep your data on.
I suggest turn on your data, then enable data saver. That will remove that notification. But you won't use up data because that disables data by background processes.
You'll have the data saver icon on the bar though. It looks like a circle with a plus sign.
Did you try any of the suggestions above?
Just wondering, why not?It wont work.
<span style='font-size:14px';>A bochur </span>
<span style='font-size:14px';>Did you try any of the suggestions above? </span>
It wont work.
