please help
Fiezta
Hello there and happy Friday, please can anyone or someone help me out, there is an apps I used to have on my phone and I could no longer remember their names once my fone is factory reset.
The first is an app that let you combine multiple contacts into one on your phone (e.g. let's say you have two numbers with different names
The second one is the app that let you send repeated text msgs to ur contact(s)...you can program the app to send like 40 msg to just one person or multiple repeatedly
Thanks for your help
The second app is called "contest winner"
My phone has the feature to link contacts there already. No need for another app. I'm not sure if that is part of HTC Sense though. It could be.
Yes, I think my Nexus one also came with this feature before but ever since I got it back from being factory reset, it is no longer there. I called the support today and they asked me to go into my google contact and merge my entire duplicate contacts...I try to do this but it is still not working for me. I went into contacts and under it I picked find and merge all duplicate contacts
