No offense meant, but your country's political establishment severely restricts internet access. I'm guessing that android devices (with their completely open platforms) might make controlling access difficult, which might explain why they are not more widely available. I strongly suggest that you download Opera browser (the latest version - 10 I think) to your computer. Its Turbo feature should bypass many (if not all) of the regimes internet filters and allow you to access to those pesky sites they don't want you to access. If that one doesn't work for you try Maxthon, it should do the same. As I understand it you are basically accessing out country proxy servers to run your searches and get your information, so they are not subject to your local internet censorship. Good luck.first of all I'd like to thank you very much for your prompt and thorough answer.
unfortunately because of sanctions and limitations in my country,companies like HTC do not give us handsets using android. sony-ericson's Xperia X10 is the only android phone sold in our market! others do not have guarantees and are imported illegally.on the other hand you can find windows based handsets abundantly and easily. so almost no one knows about androids apps. for example we use MS office applications for most of our research programs that I am totally unaware if they work with android.
there for the only way for me to answer my questions is to explore websites and forums...I checked links you have mentioned but I could not enter the last two.it says access is forbidden and I don't know why! do you know why?!
P.S. I live in Iran
