Please tell me what "roaming included" means!
JohnJSal
Android Expert
I just switched to the Everything Data 450 plan and it says "America - Roaming Included." Does this mean roaming calls are *free*, or just that I have the *ability* to make roaming calls?
I ask because I'm pretty sure I had "roaming included" on my last plan (a custom Free & Clear plan) yet I still occasionally had roaming charges. Just this month I somehow have a $15 roaming charge.
Perhaps I'm wrong about my former plan, but what about my current one? Will I still be charged for roaming or is it completely free now?
If you're in the USA, you don't pay extra for domestic calls. However, "Any Mobile, Any Time" will not follow you. Those calls will count against your 450 allowance, or night/weekends, if applicable. Data access will also vary, with most carriers only extending 1x service to roamers.
The original "Free and Clear" plans, if I can remember back that far, allowed for no roaming charges on any other Sprint system around the country, but charged for non-Sprint.
Ah, so even when it says "roaming included," that only applies to phone calls and not roaming data usage?
Fine print on sprints plan page 300mb limit on Roaming Data.
Voice/Data Usage Limitation: Sprint reserves the right, without notice, to limit throughput speeds, and to deny, terminate, modify, disconnect or suspend service if off-network usage in a month exceeds: (1) voice: 800 min. or a majority of minutes; or (2) data: 300 megabytes or a majority of kilobytes. Prohibited network use rules apply. See in-store materials or sprint.com/termsandconditions for specific prohibited uses.
Also for the OP, if you went over your 450 minutes then roaming is no longer included in the overage minutes. You pay full roaming rate for those minutes.
Well, prior to my 450 plan I had 1000 anytime minutes and I know I never went over that. I also didn't use more than 300MB of data.
