I'm rooted on BP so I really hope I'm posting in the correct area of the forum...if not hopefully this can be moved.
I use Temp + Cpu Pro and System Panel to monitor the cpu activity and which apps are responsible. The issue is that with my device setting on the table and the screen on so I can watch the cpu monitors the cpu frequency and percentage of use are all over the place. In other words constantly changing. I have taken a look at which apps are active during the spikes and Holo Launcher and System Panel are on the active list but causing a minimal amount of activity. Now I have turned off all wifi, data and background activity, no change. I wiped everything, re flashed BP and started over. Before setting up my normal apps I DL'd System Panel, Temp + Cpu Pro, No Frills cpu and nothing else. The erratic activity is still going on. I tried using lag free governor and the frequency spikes still occur theres just a slower decline after the spike. I tried on demand and the problem persists. I'm now on the conservative governor and it does a good job of managing the frequency spikes by moderately maintaining a low frequency and the spikes occur a lot less often. Now the % of cpu usage is still all over the place, 4%, 18%, 1%, 23%, 9%, 6%, 31%...I'm sure you get the point.
Can someone take a look at their cpu activity with the device undisturbed and tell me what they see? Ive exhausted myself on this issue and I hope someone can HELP ME FIX THESE ISSUES...PLEASE HELP???
