pls help me
rohit123
guys pls help me...
i have recently updated my galaxy fit to gingerbread 2.3.4
i also did factory reset after the upgradation process
yet i am still facing problem that my phone is not able to connect to pc with usb connection,it displays on cell in notification bar usb connected and charging also happens......yet when i try to open it by going through that notification bar i fail...help pls asap...pls
Samsung phones are very fussy about the cables that connect for data. You should make sure you use the one that came with the phone.
