Firmware is device-specific, often even carrier-specific. If FDR and clearing cache partition didn't help, and you are unable to obtain firmware, you may be out of luck. If it's not a wifi-only device, check your carrier's website to see if ROM download is available.i contact the manufacturer but they said that they dont have the firmware of that kind of tablet (pointing the Lifetab s7582) so how can i fix it?? can you suggest any kind of solution??
