pls help ..,
Hello, mhelspike. :)
Welcome aboard. Check out the following steps below. Here's hoping you'll find this place usefull.
Go into Settings ---> Applications ---> Manage Applications and wait for this list to be populated with not just the applications but the amount of memory they are using up. Select a larger app and on the next screen if the the app can be moved to the SD card you'll be able to push the Move to SD button. Repeat the process for each app.
Welcome Mhelspike to Android Forums, :ciao:, look around and enjoy. If you have any other questions we will guide you to the proper forum section as this is simply an introduction section and there is not much support here in this section :congrats:
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
