Hello, as I said before I can listen to other podcasts and this one in particular I had listened to for over 2 years and then earlier this summer all of a sudden the audio was not coming through, I checked with the Podcast and they knew of no others that were having this issue. I would much rather just go to the site and stream the podcast than download it. I was asked to post a link to the Podcast so here is todays:
https://garagelogic.com/episode/10-...sful-means-of-testing-our-downfall-continues/
I can go there and click play and I can see that it is playing but there is no audio whatsoever.... It just seems extremely weird, just totally odd that I can listen to anything else (podcasts) except Garage Logic's shows.
Well, I checked the link, and it plays just fine for me.
I am using a fork of a great browser called Lightning, and the fork is called Midori.
This is not my normal browser, it is just the one that I have set up for this site.
Perhaps the issue is within whatever browser you are using.
Yes, I understand that you can listen to various other podcasts- but not all podcasts are formated the same, and not all browsers can utilize all formats.
You didn't say what app or browser you use to listen to these podcasts, so I cannot test this myself at this point.
At any rate, Lightning is a top notch browser, and so are various forks of it that are available and have various different features.
Perhaps, as I did with this site, you could use one of these browsers as a dedicated app to listen to these podcasts.
I just make the homepage into the site that I desire, and use bookmarks to navigate.
You could have as many podcast links as you like for bookmarks, and tabs are unlimited as well.
https://f-droid.org/en/packages/acr.browser.lightning/
https://f-droid.org/en/packages/org.midorinext.android/
https://f-droid.org/en/packages/com.cookiegames.smartcookie/
