Point to Pin, an alternative to map-based navigations
ZinSoo
Point to Pin:
https://play.google.com/store/apps/details?id=com.zinsoo.android.ptop
if you are not comfortable with reading maps and finding your way in them?
and just want to know which direction you should go?
Get this app and it will always show you the direction to your destination by an arrow and also gives you the distance to your destination. Easiest way to find a place!!
you just need to go to this website ZinSoo
and pinpoint your destination on the map in this website and receive a unique ID for it.
Then enter the ID in your app and never ever lose the way to that place.
