Hi all,
I recently bought a cheap 10" tablet of eBad for my young son, last week the wifi stopped working and wont switch back on, if you try to switch it on in settings it says turning on wifi, but does nothing and the switch returns to off.
I read on the net about a similar problem that somebody had, they said they had a virus so I downloaded 360 antivirus and done a scan. The scan found a virus in one of the android files but it could not remove it as I could not give 360 root permissions, so I have since rooted it using Kingo and gave 360 root permissions, the tablet is now clean but the wifi still wont work.
Here is the system info:
Processor = DualCore-A23
Model = GA10H
Android ver = 4.2.2
Firmware ver = v2.0.8
Kernel ver = 3.4.39
android10@Linux2 #302
Wed Mar 26 17:38:42 CST 2014
Build = polaris_eng 4.2.2 JDQ39 20140326 test-keys
Does anyone know if this can be updated straight to 4.4 Kitkat? Does this problem sound like a hardware or software issue?
Also can some annoying apps be deleted, DU speed booster always pops up saying its stopped working, also is there a list of minimum apps needed to operate?
Thanks in advance, please note im new to Android so go easy.
Lee.
Model = GA10H
Android ver = 4.2.2
Kernel ver = 3.4.39
Lee.
