Populate ListView with two tables in Android
faran100
hello,
I have two tables. Arabic and urdu. I want to display select query to listview Line by line (arabic/Urdu).
I Have no issue to display one query to listview but I am failed to multi select from 2 table and populate Listview.
Code:
(Private feedback for you)
I have two tables. Arabic and urdu. I want to list Line by line (arabic/Urdu) for display Arabic i have no issue
Cursor cursor = myDbHelper.Surahbyid(Value);
        // The desired columns to be bound
        String[] columns = new String[]{
                myDbHelper.KEY_AYA,
                myDbHelper.KEY_TEXT,
        int[] to = new int[]{
                R.id.id,
                R.id.aya,
        // create the adapter using the cursor pointing to the desired data
        //as well as the layout information
        dataAdapter = new SimpleCursorAdapter(
                this, R.layout.surah,
                cursor,
                columns,
                to,
                0);
        listView.setAdapter(dataAdapter);
