First off I want to thank these Dev. for there hard work..
Kam187, Mastermind278, droiddev, mobileband, My420Time, rkhalil2009, Nu11u5
ODIN Install Ready. Updated Build to T939UVIJ6
Download here > BH-MAN-ODIN.tar.zip
Change Log:
- No Factory Reset Required after Installed!
- Galaxy Bootup Screen.
- Modded Shut Down Screen
- Added The Internet Speed Boost Hack to Build.prop ( Confirmed Working ).
- Removed Cube Launcher
- My Faves's Removed
- New Kernel - Rooted & SU Permission Fix.
- New Wallpapers ( Android Pictures ).
- New's & Weather ( Back ported to 1.5 ) Non-Paid App!
- Better Terminal Free edition. ( Landscape does not work. )
- BH2 Mms added back for Picture MMS to work correctly.
- Optimized Entire Build.. ( Optimize Mean's Compressed Images to load Faster ).
- Galaxy Setting.apk
- Framework-res.apk Is now Mostly Stock Android Color's
- Galaxy Switchers.apk ( Turns on BT / WiFi / GPS / Sync ).
- New Ring Tone's
- New Notification Tone's
- Cube Button is Remapped to Search ( My Preference ).
- Bloat ware Removed again
- Root for App's via kernel
- Persistent Root via kernel
- Advance Launcher that I merged with TwLauncher ( With Personal Touches )
- Galaxy Launcher ( With Personal Touches & Home Screen Does not Rotate, Some Prefer this ).
- Busybox Installed
- Likely Stuff I forgot*
- If I didn't mention Something in the Change Log, then there was a Reason For it, so Don't go Posting about it.
Trouble Shooting ODIN Flasher
WiFi FIX For the Older Kernel!
* Download bcm4325.ko
Place the File on the sdcard of the Behold 2 ( Don't Forget to Un-mount after )
Now we Open cmd prompt & type the Following
Back To Stock TwMms
Original TwMms TwMms.apk
Place onto your sdcard ( Un-mount )
then do the Following
Change Log: Using The New File's.
- My Faves's Removed ( Removing the Call Function was a Pain, as it Crashed the System looking for it ).
- New Ring Tone's
- Galaxy Mms.apk
- Device Manager is Removed ( Sorry, but Pointless in a Custom Rom ).
- Removed Most of Samsung's Call Home app's
- Removed Amazon
- Removed Widget Pack
- Batterystat.bin is auto removed for Better Life. ( You will See a New Time stamp Per Boot! )
- Still Using Advance Launcher that I merged with TwLauncher ( With Personal Touches )
- Busybox Installed again
* Download the Package here > BH2_No_Twiz.zip
Change Log / Int. Release.
Included & working in rom Plus hassle free install is>
- Pre installed Busybox
- Galxay Mms.apk
- Removed TwMms.apk
- Root for App's
- Widget Pack
- Merged Advance Launcher w/ Twiz Launcher.
- Persistent Root script pre installed
- US by Default
- English By Default
- Bloat Ware Removed.
-Bugs Known
- USB Debugging needs turned off, then back on after each re-boot for adb to work..
Now, I've spent a lot of time in making it less difficult for everyone to install the Rom & hope everyone like's it.
Once download is complete, un-zip the items to the SDcard on your Behold 2.
Now for the Install procedures.
Do the Following one Line at a time...
Install Key * Is For Old Install * is For New Install!!
Step 1.
Now, once you have Rebooted, Do a Factory reset by, Menu>Settings>Sd card & Phone Storage>Factory Data Reset Enjoy!
Trouble Shooting!
Stuck on Samsung Logo..
You Need to Do this First Before Pushing this system File over.... You can't have the Galaxy Rom installed Prior to installing this...
Pictures Running.
Original method/discussion for Galaxy system on Behold 2
http://androidforums.com/samsung-behold-2/35487-galaxy-stock-android-behold-2-flies.html
You Must Un-zip the Package First!
Then Load the .md5 into PDA in Odin Flasher
Change Log:
- New Ring Tone's
- Busybox Installed
Okay let me help you step by step!
1. Open up Odin Multi Download
2. Under Select OPS, choose Behold2_partition.ops
3. Click PDA, choose T939UVIJ6-PDA-CL81521-REV1.tar.md5
4. Power Off Phone
5. Make sure you have it connected via USB
6. Hold and Press Volume Down, OK, Power (the red end button)
7. Phone will say Download Mode
8. Click Start on Odin Multi Downloader.
9. Wait a couple of minutes
10. Stock Touchwiz phone working again!
The ODIN Files and orignal firmware can be downloaded from the following link: http://shrunk.me/uvij6.zip
*Everything Below is Out Dated!*
* Download Here > BH2_No_Twiz_UPDATE.zip
Remember this is For the Older Kernel. So, If your wifi no longer works, follow these Directionsadb shell
cat /sdcard/bcm4325.ko > /system/libmodules/bcm4325.ko
Back To Stock TwMms
adb shell
cat /sdcard/TwMms.apk > /system/app/TwMms.apk
- New Ring Tone's
- Galaxy Mms.apk
- Removed Amazon
- Galxay Mms.apk
- Removed TwMms.apk
- Root for App's
- Widget Pack
- US by Default
-Bugs Known
Step 1.
Step 2.adb shell
cat /sdcard/try3 > /data/local/try3 **
chmod 777 /data/local/try3 **
/data/local/try3 /system/bin/sh **
Step 3. Wait for the # sign after /data/local/unyaffs /sdcard/system Before Rebootingmount -o rw,remount /dev/st9 /system **
cat /sdcard/unyaffs > /data/local/unyaffs **
chmod 777 /data/local/unyaffs **
That's it, after you get the # from running /data/local/unyaffs /sdcard/system it's now safe to reboot...cd /system **
rm -R app **
rm -R framework *
rm -R lib *
/data/local/unyaffs /sdcard/system **
reboot
Trouble Shooting!
Pictures Running.
