superboy4444
Android Expert
I present you with Party Time JB. Just what is Party Time JB? Well, it's a ROM based on Martinez41613 Super Stock ICS ROM and it is a WIP (Work In Progress). It features things from Android 4.0, 4.1, & 4.2. I plan to work on this ROM to improve it. I hope everybody likes this ROM.
PartyTime JB ..::Party Time JB-Prevail.zip | by Superboy4444 for Galaxy Rush::..
android file host just granted me a dev account so now i shouldn't be having any more traffic issues from now on!
Changelog:
v1.2
- Reverted to TouchWiz 4
- Added stock music player
- Added live wallpapers
- Replaced messaging app with Samsung galaxy stellar mms
- fixed email issues
- Removed Stock ICS Gallery
- Added Favorite App Widget
- Changed Installation Scripting Slightly
- Added Swype Installer
Bugs:
- Mobile Networks in Settings App Is Broken
- Wi-Fi Direct in Settings App Is Broken
Note: Don't flash G-Apps...It will ruin this rom
Disclaimer 1: If this Mod bricks your device there are a lot of things you can do to fix it. All you have to do is check on this forum. Also, if this Mod damages your device in any way, I take no responsibility, it is nobody's responsibility but your own. That being said, I have already tested and it finally runs perfectly on my phone.
Disclaimer 2: While installing this ROM using CWM Recovery, you will notice some profane language. If you are uncomfortable with this, the best i can do for now is say sorry.
Installation Instructions:
1. Download ROM and place wherever you would like (I keep my ROMs in a folder named ROMs located in my external sd card).
2. Boot into CWM Recovery
3. Wipe Data/Factory Reset
4. Advanced
5. Wipe dalvik-cache
6. Reboot recovery
7. Select Install zip from sd card
8. Select either install zip from sd card or install zip from external sd card
9. Select folder where you put PartyTime ROM.
10. Select PartyTime Rom (The Name will be PartyTime ICS because I forgot to rename it after updating).
11. Install
12. Reboot system
13. Wait at least 20 minutes before calling it a fail.
14. Voila
15. Welcome to the party!
Thank you everyone for your help including:
Martinez41613 for the Super Stock ICS ROM
TylerMetcalf1998 for working on this ROM with me over the phone
MikeyXDA for the Google Now Mod
WanamLite for the working S-Voice pulled from the SIII
And anyone who downloads this ROM and gives me input!
Thank You,
Enjoy!
Be sure to hit thanks or like if you njoi this ROM!
Changelog:
v1.2
Bugs:
4. Advanced
6. Reboot recovery
11. Install
12. Reboot system
14. Voila
Thank You,
Enjoy!
