Possible to create a shortcut directly to Astro's Process Manager?
Instead of installing another program I would rather just use Astro's process manager, it works plenty well for what I want now. I know you can use Anycut to rename and create shortcuts to most things, but is there a way to create a shortcut to a function within a program? If not with Anycut, maybe a different program?
Yes there is. Open Astro File Manager, at the top there should be a menu bar if there isn't press the down arrow on the right one will show up. Scroll to the right and you will see setting switch, a wrench with a person, it is after the sort button. Press that and it should bring up the Preferences menu. Scroll down to the Helper Apps section, press Home Screen Icons. Check which icons you want displayed on your Home screen.
Hell yeah, you are the man!
Thanks!
