I have two usb ports on my 10' tablet, I wish to use a usb wifi dongle to increase the range of my wifi.
However when plugging it in it is not recognised, yet it works ok on the PC
Any ideas how to get it recognised???
Thanks
Search in this article for 'USB On-The-Go'. And then have a look at your tab's USB ... maybe it is your solution
USB - Wikipedia, the free encyclopedia
Harry
Are there Android handsets without WiFi not already built in? I guess I'm thinking plugging in a wireless adapter would be redundant and merely turning the WiFi on in settings will give you what you are looking for..
I looked thru your welcome suggestion however could not see anything that would help.
However it maybe there a little technical for my grey matter.
All help is appreciated.
Thanks![]()
