That part of the port might be starting to corrode from the water. The green might be the corrosion.
How would u get rid of the corrosion I heard maybe alcohol or peroxide
I would use Isopropyl Alcohol and a stiff brush.
Well It was in the water for at the most of 3seconds using it now I let it dry and started charging it and now is charges a bit shower than normal sand there is green stuff on the port were u charge /still charges thank god and everything works what is that green stuff on the charging port
Would u have any links for me so I could look at what you're talking about and then I'll go some
You don't really want to let your device sit for days in a rice bag while the water starts to take its corrosive action. That is why air is the best....it removes it immediately and the water doesn't have time to chemically interact with the metals.Its true that water can be corrosive, but if you clean it up right away, chances are there will be little or no damage at all down the road. I used COMPRESSED AIR to fix water damage. Works wonders. Here is a link to explain it:
https://sites.google.com/site/cellaphoney/home/water-damage
Forget about rice, ovens, heat guns...etc. Air works the best. If you clear ALL the moisture from your device, you don't need to run Alcohol through your device. Waste of time in my opinion.You don't really want to let your device sit for days in a rice bag while the water starts to take its corrosive action. That is why air is the best....it removes it immediately and the water doesn't have time to chemically interact with the metals.
Plus, I am batting 1000% on my fix percentage, and I see zero corrosion on my own phone I dropped in the river.
Yes, I do ultimately agree with you valorian that it is possible some corrosion can continue. If the water is left to sit for a while, your chances of corrosion are much higher, but if you get it right away, there is much better chance. There are always 100 different ways to do something, and most people are lazy or don't have time, (like me, both lazy and don't have time), to fix things 100% properly. Taking the whole device apart and doing your method with the alcohol is..well, probably the "best" way. But what I have found so far, is that the compressed air method seems to be the best bang for the buck, works immediately, and so far, the phones I have fixed with this method are still working today...at least 5 I know for sure, the others I have no contact with.Plus, I am batting 1000% on my fix percentage, and I see zero corrosion on my own phone I dropped in the river.
Looks like we are in agreement. I wasn't trying to suggest taking the unit apart. I was just instructing the OP to use a brush and clean the connector where they are seeing the green corrosion.
