Root Possibly a system ui mod?
What's the error you're trying with the decompile? Did you install the framework? what version of apktool are you using?
I was wondering the same thing. I love the card based multitasking of lollipop and kitkat touchwiz recent apps look too simple. Is there a way to just flash a zip file that edits the systemui without having to decompile and manually do it. That would awesome.
I built it from my my systemui if you're using that good to go. If not and you flash this you'll have few ex mods
https://docs.google.com/file/d/0B62c5GHvW-zaS0RBWG9RZ3hZMFE/edit?usp=docslist_api
That's what it does man. I followed the tut
I trust you. I'm just asking if it worked correctly, because it's supposed to make the ui stack like cards from lollipop, they said it might have issues with touchwiz Roms but it was worth a try anyway. Thanks!
It still looks better than stock imo
