Root Post your "SD Tools" results
SD Tools is used to measure the speed of your external memory card.
Description:
SD Tools - Info and Benchmark tools.
With SD Tools u can check your microSD card info(Name, Date, MID, OEMID,...).
You can check if your card is fake. (Check serial number and MID and OEMID).
You can also benchmark sd card writing and reading speeds.
Post your results here with the following info:
Brand of memory card
Capacity
Rated speed/Class
SD tool result
Example:
Verbatim | 16GB | Class 10 | Read: 16.2; Write: 9.5
You can also post a screencap of the SD tool result
This will help us see:
Performance of different brands of same/different class rating
If class of card matches with real world performance
Performance of Stock/Bundled memory card
Since we are low on ram and using swap, speed and class matters a lot...
