Power Control Plus Broke My Phone.
Fbstar
Okay, well I am using the Samsung Galaxy S Continuum by Verizon Wireless.
I downloaded the Power Control Plus app, Made a 1x4 Widget with just the quadruple brightness button on it. I clicked the brightness button once, got bright, twice, got brighter, 3 times, really bright, and 4 times and my phones brightness turned off!
Well the only way to turn off my phone now is to take out the battery. When the battery is reinserted and I power it up, everything is normal and boot up is normal but when my lockscreen shows up everything is just pitch black. It's not that I can not see it is that it isn't working. If I click my power button twice while the phone is on the lockscreen appears for a split seconds very dimly.
Is there any possible way to fix this?
