Power control plus
Ash1807
Just installed the above, and also set it up on my home page, but I cant get past the first set of instructions that tells me how to set up the widget shortcut.
In short, I am not seeing the controls setup coming up.
Anyone with an ideas ?
Just in case this is a case of not trying to launch it as a widget, here's how:
1. Long-press on an empty space on your homescreen.
2. A popup menu appears - choose "Widget(s)"
3. Wait for the list of available widgets to load.
4. Scroll down to Power Control Plus and select it.
5. A new screen opens up with a small preview of the widget on your homescreen up top and a bunch of options beneath it.
6. Chose how many buttons you want and what each one will do. The preview up top changes accordingly and you can even try it out to see how it works.
7. Scroll down to the bottom and click on OK / Save & Exit / Whatever it says
8. The widget is placed on your homescreen.
If you haven't got sufficiently space for the widget it won't be placed, but otherwise I can't see how it shouldn't work.
