Power Max app
westkc3
Member
Curious if anyone has used this app and if so, what you think about it.
The following is a bit confusing;
"When Power Saver Mode is on, your phone's functionality will be significantly reduced. But don't worry, this is just to save you power, you can always use your mobile's features on demand (email, internet applications etc)".
If that means you won't receive e-mails or texts while it's on, that I can live with. On the other hand, if it means I won't receive phone calls while it's on, that's a whole other thing.
Sorry you found that confusing!
PowerMax never turns off the 2G cell radio, so you can always make and receive calls and text messages. Depending on the PowerMax setting (Max, Standard etc) you may not be able surf the web or use email, or you may simply need to manually sync your email.
Joseph from VoltUp
