Help Power on button do not function!!!nexus one
krieldan
I bought my phone last june and got this power on button problem and it's not working anymore!can anyone help me how to get rid of this????or any option how to turn my phone on!?plsssssssss help!:(
Hello and welcome to Android Forums! :)
I think the phone will power on or wake up if you plug it into a power source after the battery has been pulled and then replaced. Once you do that there are apps you can install that will wake the phone up with the trackball.
Personally, I had to remove and replace the batter several times before it finally powered on and I could back up all my files.
Plus, if you call HTC and file a ticket, they will replace your power button for free, even if it isn't under warranty, as long as you haven't rooted your phone. The only drawback is that you'll be without your phone for ~10 days. At least that's what happened for me in the US.
Once I got my phone back, I installed lock widget so that I can lock my phone using the widget rather than the power button. Hopefully it will make my power button last longer this time around.
I haven't tried any of the other apps such as the ones that turn your volume or trackball into power-on to wake up your phone. I'm a bit nervous about if that wouldn't wear out those buttons too. At least HTC admits theres a problem with the actual power button and will fix it. Don't know if they'd do the same for the other buttons.
They will fix it for free? I had the power button on my N1 fail two weeks after the warranty expired and they refused to fix it w/o me paying for it.
Kage_
