p1r4te
hi all.
i have been looking on google on & off for a solution on the internet for the past year to disable the "power options" on the lock screen.
As of 20/12/11 (my birthday) my faithful cm7 rooted moto milestone was stolen from my vehicle.
Basically i need to find a way to disable the power options on all my android devices from the lock screen, so the only way to turn it off is by unlocking it and then turning it off.
I can glue in the battery, since i have acetone to remove the glue if i need to remove the batt in the future (only once did i need to remove my batt on my ph, and that was the time i put the sim in).
My skill level is in my opinion average, and basically i can get around most things with a good guide. the only thing i havnt been able to achive is to set up a personal wow server on my ubuntu server rack (wich is beside the point anyways).
Please help. If you know of an app or a way to do this, please explain it!
I really need a solution on this, because if another one of my phones gets stolen, i want to be able to find it (or blow it up so that it causes serious harm to the thief ;p).
Im pretty sure that the ph was turned off or the batt removed because the ph didnt respond when i sent commands to it, or when i tried to ring it...
thank you for your helpful and constructive reply.
