Puddy Tat
The back on my old Huawei was simple to remove, replace the battery, and replace the back. On my new one it has little "hooks" that hold it in place. It is scary every time I open it. Makes me think it is going to break. With this in mind, I was thinking about a battery pack or a power pack(whatever you call them)to use for extra power when battery goes down instead of buying a second battery.
Has anyone used on of these and do they charge the battery in a short time or over many, many minutes? Can you use the phone when one is connected?
PT
PT
Those typically range in capacity 10000 mAh and higher (anything less only makes sense if its a slim package), and offer at least 2 usb outputs with 1A and/or 2A. I'm not familiar with your Huawei phone, but it sounds like an old model which probably has a charging speed of no greater then 1A. Using one of these external batteries you will charge your phone as fast as from wall outlet.
