Power Toggles widget
nightowl66
I use the power toggles widget on my Samsung S10e. The app hasn't been updated since 2015. It still works, but with every Android update it seems to loose something. I know I can use the quick settings menu, but I like having the widget on my home screen for volume, brightness, bluetooth, wifi, flashlight.
Any recommendations on a updated widget?
Go to the play store and do a search for settings widget. There are many
