Just wondering what the options are to power a device which battery has died and is no longer replaceable? Is it possible to use a portable battery back to permanently power the device?
Is the battery inaccessible or simply not available?
Not sure if you live in the states but if there is a Batteries Plus store near you they may be able to get a hard to find battery or possibly rebuild it.
Actually I was thinking about picking up an old phone as using it as a portable MP3 player. Just planning ahead if the battery is no longer holding its charge.
