To do print screen I would use that key and control on the computer, right? Then to view I would go to paint and do ctrl v? To save is ctrl s, isn't it? Then why isn't it working? It just plays that music.
IF you are talking windows PC, then the Print Screen button on the keyboard will capture the entire screen image at the moment the key is pressed. If you press alt-prtscreen, then only the active window is captured. From there you should be able to past into many different programs.
Paint certainly should work. Ctrl-V is paste and Ctrl-S is save so you seem to be doing it right. What music plays when you try?
It's just that "not happening" chord. It sounds pretty but it doesn't really do anything as far as I know. I just want to save the image and be able to find it later. Where does it go, anyway? It's Windows 8.1, which I don't really like, but I don't know how to get 7.
