print text messages
  • Start date Start date
There is no way built into android directly, however there is a bit of a workaround you can use. The first step is download this app from the Play Store which will give you the option to paste data to the internet. Simply copy the data you wish to use from your texting app via a long press and hitting the copy button on the pop-up (or the clipboard on some phones) and then going to the downloaded "Paste It" app and long-pressing the input box and selecting the paste icon from the pop-up. Then go to the given URL on your computer and print the page.
This gives the body text but not the time and date. It is also difficult to print a long thread of messages. Is there an app for this?
