print to laser printer
  • Start date Start date
Hi, glad you came to Android Forums.
You could try installing Printbot. Once you install the app, try the following instructions.
My printer does not have any network. It is attached to my Windows PC.
Windows 7 comes with LPR support as a "Windows feature". This will work if you
  • install and enable the LPD service on your PC via System Settings/Programs and Features
  • use LPR as the protocol
  • put in your PC's IP address as host
  • put in the printer name as queue
From Printbot Setup
