Printing documents using wireless connection between Android device and Printer
I need some advanced option in terms printing documents using my android device and printer.
I can connect my android phone and printer using the same WiFi network but during printing i need a option like "Keep printed documents" like the windows PC have. I need a solution for this problem.
Here I've attached a image file which might help you what kind of advanced option i required.
Please help me in finding the solution.
The only way to keep printed documents that are on the phone is to manually transfer them using a file manager from phone to PC
I know we can do this by using file manager but my question is that, is there any other way to capture the data while transferring through WiFi network.
