Problem after using SDMaid
rweeyums
I have a ZTE warp rooted and installed the SD Maid. I did something I shouldn't have (I guess) and now my music won't work, my camera doesn't work and I have random "the process android.process.media has stopped unexpectedly, please try again". Not sure what to do :confused: Help please!
You're likely better off asking this in the sub-forum for your device. That being said, can you elaborate on what SD Maid is and does?
Alright, I have a pretty decent idea of the app's purpose. OP, you're finding that error message on all media? Perhaps did you delete some system files, that it may have misidentified? If that's the case, you're rooted and can replace when you deleted. If you don't know what you're missing, I'd recommend wiping and reinstalling the ROM (or a new one), as that'll start you fresh.
