-- Problem connecting A20 android box to hotspot -- any help?
myandbox
Hello all,
Im a bit new to the XBMC world and starting to discover all its glory. Have a couple of different android boxes that have worked perfectly. The problem is I received a couple new A20 boxes and they have no problem connecting & running on my home WiFi but when I try to connect via hotspot from any phone I get an unending string of error messages popping up on the screen "System configuration is inconsistent with production configuration, please contact your supplier" has anyone ecperienced this and have a work around?
Thanks!
have the same problem please let me know if some one replies to you or maybe you found out by now and you can share this with me thanks in advance
I would also appeared the message "System configuration is inconsistent with production configuration, Please contact your supplier". Change the firmware to another more simple, that gave me the supplier. I would put here but I think downloads are prohibited.
And the message no longer appeared. I only use for movies from ethernet. I did not test with other applications. To solve that are not well connected to the ethernet network, install "Mezzmo" on the server and application "Skifta" in TVBox client.
Hi guys, I'm fairly new to xbmc. I recently bought a box from china and when starting this box up for the first time the same error message cam up. Did any of ye get it sorted??
Does changing the firmware sort this? My box doesn't seem to connect to my wifi either.
Multiple A20 boxes from China all with apparently fluky networking, being what they are, there's very likely quality issues with the manufacturing. Not a lot can be done with them, except RMA for replacement or refund(preferable).
