Help Problem downloading map to Maverick
I've created a map with Mobile Atlas Creator and saved it as an atlas in RMaps SQLite format. I renamed the file from "Custom Whatever" to a more descriptive name, keeping the same extension. I've copied this to the Maverick/maps folder on my tablet. I'm running Maverick Pro, opened the Map Sources list, and selected the map which shows up under Atlases at the bottom of the list.
When I go back to the map window, the title bar says "MapQuest" and the downloaded map is not being used. (When I turn off WiFi, nothing is displayed when I zoom or pan.)
Is there a step I'm missing? What can I do to have Maverick really use the downloaded map?
