[Problem] Error at install: Application not found.
Hey guys, I'm new at this forum and I have a problem with installing a apk
I have tried yesterday to download/install the n64oid and I tried atleast 20 different apk's but I'm getting the same error
If I try to install the n64oid I'm getting the following erorr: Application Not Installed
So I also tried it with the adb but the same error occurs
Log from adb trying 16 different apk's
Code:
844 KB/s (482439 bytes in 0.558s)
        pkg: /data/local/tmp/11n64.apk
Failure [INSTALL_FAILED_INVALID_APK]
java.io.FileNotFoundException: /data/logcat_0.txt
1946 KB/s (488365 bytes in 0.245s)
        pkg: /data/local/tmp/N64oid (N64 Emulator) (1.1.4).apk
2029 KB/s (488365 bytes in 0.235s)
        pkg: /data/local/tmp/N64oid 1.1.4.apk
1892 KB/s (488365 bytes in 0.252s)
        pkg: /data/local/tmp/n64oid 1.1.14.apk
1733 KB/s (488300 bytes in 0.275s)
        pkg: /data/local/tmp/N64oid v1.1.3.apk
2014 KB/s (703546 bytes in 0.341s)
        pkg: /data/local/tmp/N64oid v2.2.1 [UPDATE SOON] .apk
2003 KB/s (488365 bytes in 0.238s)
        pkg: /data/local/tmp/n64oid(1).apk
2057 KB/s (482439 bytes in 0.229s)
        pkg: /data/local/tmp/n64oid(2).apk
1847 KB/s (482439 bytes in 0.255s)
        pkg: /data/local/tmp/n64oid(3).apk
1899 KB/s (488365 bytes in 0.251s)
        pkg: /data/local/tmp/N64oid(4).apk
2020 KB/s (488365 bytes in 0.236s)
        pkg: /data/local/tmp/N64oid(5).apk
2030 KB/s (482393 bytes in 0.232s)
        pkg: /data/local/tmp/n64oid(6).apk
2055 KB/s (488365 bytes in 0.232s)
        pkg: /data/local/tmp/N64oid.apk
2127 KB/s (488083 bytes in 0.224s)
        pkg: /data/local/tmp/N64oid_v1.1.2.apk
1605 KB/s (488300 bytes in 0.297s)
        pkg: /data/local/tmp/N64oid-v113(1).apk
2037 KB/s (488300 bytes in 0.234s)
        pkg: /data/local/tmp/N64oid-v113.apk
Press any key to continue . . .
I just don't understand why I'm getting that error all I want to do is installing it and play some games
I have been searching alot at google but couldn't find something to solve it
I've been looking at my phone and I just found the logcat_0.txt
img560.imageshack.us/img560/5368/device20110828112339.png
Information about my android excalibur
img593.imageshack.us/img593/4953/device20110828112547.png
If some one can help me it will be much appreciated
