Problem Importing android project from linux to windows
kedardash
Hello,
I am finding error in src/<java file> while importing a android project developed in ubuntu to window. Android sdk version is 2.1 in both the machine.
The project is getting imported successfully (new project->create project from existing source) but all android classes are not able to finding their references and showing underlines. The import are not getting resolved.
The same thing is working fine from windows to windows import.
Look forward for help...
Best regards,
Kedar
