I am using HTC G1 there is some some problem whenever i am trying to search or google it the message comes up " The process android.process acore has stopped unexpectedly. Please try again" I am fed up with this. Could any one suggest help on this
Hello and welcome to Android Forum. I've read about a few members complaining about a similar error message popping up after first closing the application they were using. But your situation is a little different. I don't think I've read about this happening when googling. You should check over your device's home-forum to see if this issue has been mentioned before, and has anyone found the cause of it. Best of luck. All the best for 2012.
Welcome to Android Forums. I'm sorry to hear you are experiencing problems. You might consider checking in with the G1 people here and see what they might suggest.
Here is a link to the G1 area here at AF. T-Mobile G1 - Android Forums
Good luck and thanks for joining our community.
