I developed an "heavy" application (700 Mb !). With an "apk installer" application, i can install it on the Nexus One SD card (Froyo "installLocation" option). My application is heavy because of the videos it contains (located in /raw directory). The problem I have, is that it crashes when launched, with this error :
I dont't understand the reason of this error, because when i try the same thing with a lighter application (250 Mb) it runs perfectly. Has anyone of you ever had this kind of problem ? Do you know if there is a size limit for applications to work ?
Thank you for your help !
Code:
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): FATAL EXCEPTION: main
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{com.test.media/com.test.media.Welcome}: java.lang.ClassNotFoundException: com.test.media.Welcome in loader dalvik.system.PathClassLoader[/mnt/asec/com.test.media-1/pkg.apk]
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2585)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2679)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread.access$2300(ActivityThread.java:125)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2033)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.os.Handler.dispatchMessage(Handler.java:99)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.os.Looper.loop(Looper.java:123)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread.main(ActivityThread.java:4627)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at java.lang.reflect.Method.invokeNative(Native Method)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at java.lang.reflect.Method.invoke(Method.java:521)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:868)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:626)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at dalvik.system.NativeStart.main(Native Method)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): Caused by: java.lang.ClassNotFoundException: com.test.media.Welcome in loader dalvik.system.PathClassLoader[/mnt/asec/com.test.media-1/pkg.apk]
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at dalvik.system.PathClassLoader.findClass(PathClassLoader.java:243)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at java.lang.ClassLoader.loadClass(ClassLoader.java:573)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at java.lang.ClassLoader.loadClass(ClassLoader.java:532)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.Instrumentation.newActivity(Instrumentation.java:1021)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2577)
08-18 11:22:16.179: ERROR/AndroidRuntime(1250): ... 11 more
