Hi! I have a problems with texts, the mobile seems to "forget" the smsc number even if i enter it manually, with the result that when i try to send a message it gets stuck in "sending message" and the message isn't sent. The only "solution" i've found so far is to turn off and on the phone and messages then are sent but after a few minutes there is the same problem. What should i do?
