[Problem SOLVED] Playstore
idhbar
Hi, have u noticed the Android Playstore problem? Apps are downloaded properly, then during package installation it shows invalid package. Any solution for MMX A87?
yeah, it happened to me too sometimes. we need to replace the download manager.
(downloadprovider.apk)
Just clear your data or update any apps from Playstore, then try to download any apps, keep market as foreground apps.
PROBLEM SOLVED.
