Problem Texting Pictures.
On the device every picture is texted as a link.
The default texting app is Mood. That texts pictures as a google links.
I lso tested the messages app and that sends pictures as samsung links.
What i want to do is turn off the links and have the pictures directly send to to others without being a link.
Any ideas?
Thanks in advance
So it sounds like you are sending them wrong.
You should have an option within your messaging app to pick a photo from your gallery on the phone.
I have a + sign that you tap then choose from your gallery.
How are you sending them? Are you starting from the message app and then selecting the image, or are you (as I suspect) starting from the gallery app, hitting the "share" icon and then selecting a message app to send via?
If the latter, try by starting in the message app then adding an image.
Ditch using Mood and use textra instead from the play store
