Problem using ConnectBot, Freesshd and Remote Desktop to access PC/Server.
MrRalphMan
I am trying to setup a secure connection to my network for Remote Desktop connectivity.
I am using the following components.
freesshd on a windows 2003 server
Connectbot
Xtralogic Remote Desktop Client.
Connectbot connects fine and I can log onto the servers command line.
Tunneling is set up as follows.
local - 3389
Remote <server ip>:3389
When I attempted to connect to the local 3389 port from the client, it states it's connecting and then I get the message 'Connection has been reset by peer'.
When I go back into Connectbot the SSH session has disconnected.
This happens if I'm connecting over 3g or via WiFi (Obviously changing the client address for the Remote/Local addresses).
There is nothing in the servers eventlogs, apart from a successfull login in the security one. Just a connect/disconnect in the freesshd logs.
Using the RDP Client over WiFi directly it connects flawlessly.
I have tried one other Client and I got the same error, does anyone have an idea on how to resolve this?
Many Thanks,
Paul.
