Help Problem viewing MMS pictures
I am having a problem opening/viewing MMS files I receive via text. When i hit download it just says its dowloading but nothing ever shows up. Has anyone else had this problem. Looking for some help or advice.
thanks
Hi there,
I had the same problem when I recently acquired a htc magic. The problem actually came when I solved another issue with the phone, which involved not being able to visit https sites and they just came up blank. Apparently a adjustment in the apn fixed that but broke the mms send/receive. I found another site where I had to use to apn for both things to work flawlessly. I live in Denmark so the settings won't work for you, just wanted to give my five cents on where the solution might be.
Hopes it helps :).
