I recently purchased an Alcatel Pixi 4 (4) configured with Android 6. It's only got a very small internal memory, but I thought no problem, I'll use an external SD card as internal storage. I believe the maximum SD card supported is 32GB - is that right?. So then I successfully installed a 32GB SD card and formatted it as internal memory. I assumed that now I could install new apps and storage wouldn't be a problem as they would go to the SD card. However, not so with this phone. All new apps are installed only on internal storage. So space ran out very quickly.
I know that by selecting Settings -> Apps I can go through each app in turn and it will tell me where (internal or external storage) the app is located. For some (but by no means all) apps it gives the ability to change storage and move them between internal and external storage.
I'm confused because I though,t having successfully formatted my SD card as internal, it would all be handled automatically. Have I missed something and do I need to change a setting for this to happen? Secondly why are only some apps able to be manually relocated from internal to external storage?
Any help appreciated.
