Root problem with cyanogen mod 7
RayQ123
I am using a samsung galaxy mini. I install cyanogen mod 7. The porpose i install this is because i wanted to overclock it. So i sucessfully overclock it. Then all the problem came.
1. I cant find market.
2. Cant setup gmail.
3. Cant usr app that aref rom the net
Help me pls
Help me pls
1. You didn't quite navigate around Handy Informations . If you had then you would know that it is needed to flash google apps in your smartphone after installing custom roms like cm7. Search for google apps for android smartphone there and read through the article.
2. Gmail can be setup after flashing google apps.
3. To install app from net (or sdcard) GO to Applicaitons Settings> Check UNknown Sources
