Root Problem with cyanogenmod 7.2
jurmas
I don't know how to remove it. Everybody says that downlaod stock rom and install it but i don't know how and odin don't detect my phone. Please help me, I have Samsung Galaxy Ace.
Dude everybody is right, you gotta flash stock via Odin to remove CM7.2.
How come you are using a custom rom and you don't know basics :confused:
Since the file system format of CM and stock is different, you can't just flash stock with CWM over CM. You need Odin to flash a fresh stock firmware, it'll format your device with the stock file system, and also remove CM along with it.
Now your problem is that Odin's not detecting your phone, try to google that first, you are probably not the first one with this problem. First you fix that, removing CM is easy, you just need to load FW into Odin, click flash and wait for 5 minutes. Done!
Are you sure you are putting your phone into download mode?
Sent from my GT-S5830 using Tapatalk
