Apps problem with database read in my code
msss
Dear friends,
I am new to android application development and I have written the following code to start a google map applicaton which reads some data from an sqlite databse. I considered reading database from a path as it has big data, but I encountered the error "Failed to open database '/data/data/com.mymap.www/databases/database.db'" in logcat.
Could you please help me finding the problem?
MainActivity.java
Code:
package com.mymap.www;
import java.text.DecimalFormat;
import java.util.List;
import com.google.android.gms.maps.CameraUpdateFactory;
import com.google.android.gms.maps.GoogleMap;
import com.google.android.gms.maps.GoogleMap.InfoWindowAdapter;
import com.google.android.gms.maps.GoogleMap.OnMapClickListener;
import com.google.android.gms.maps.MapFragment;
import com.google.android.gms.maps.MapView;
import com.google.android.gms.maps.model.BitmapDescriptorFactory;
import com.google.android.gms.maps.model.CameraPosition;
import com.google.android.gms.maps.model.LatLng;
import com.google.android.gms.maps.model.Marker;
import com.google.android.gms.maps.model.MarkerOptions;
import android.app.Dialog;
import android.database.DataSetObserver;
import android.database.SQLException;
import android.graphics.Typeface;
import android.os.Bundle;
import android.support.v7.app.ActionBarActivity;
import android.util.Log;
import android.view.Gravity;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.view.MotionEvent;
import android.view.View;
import android.view.ViewGroup;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.ImageView;
import android.widget.ListAdapter;
import android.widget.ListView;
import android.widget.TextView;
import android.widget.Toast;
public class MainActivity extends ActionBarActivity {
    private MapView mapView;
    DatabaseHelper dataBase;
    Typeface typeface;
    private GoogleMap googleMap;
    @Override
        setContentView(R.layout.activity_main);
        try {
            // Loading map
            initilizeMap();
        } catch (Exception e) {
            e.printStackTrace();
        // Changing map type
        googleMap.setMapType(GoogleMap.MAP_TYPE_NORMAL);
        // Showing / hiding your current location
        googleMap.setMyLocationEnabled(true);
        // Enable / Disable zooming controls
         googleMap.getUiSettings().setZoomControlsEnabled(true);
         // Enable / Disable my location button
         googleMap.getUiSettings().setMyLocationButtonEnabled(true);
         // Enable / Disable Compass icon
         googleMap.getUiSettings().setCompassEnabled(true);
         // Enable / Disable Rotate gesture
         googleMap.getUiSettings().setRotateGesturesEnabled(true);
         // Enable / Disable zooming functionality
         googleMap.getUiSettings().setZoomGesturesEnabled(true);
     // Setting a click event handler for the map
        googleMap.setOnMapClickListener(new OnMapClickListener() {
            @Override
            public void onMapClick(LatLng latLng) {
                // Creating a marker
                MarkerOptions markerOptions = new MarkerOptions();
                // Setting the position for the marker
                markerOptions.position(latLng);
                googleMap.setInfoWindowAdapter(new InfoWindowAdapter() {
                    // Use default InfoWindow frame
                    @Override
                    public View getInfoWindow(Marker arg0) {
                        return null;
                    // Defines the contents of the InfoWindow
                    @Override
                    public View getInfoContents(Marker arg0) {
                        // Getting view from the layout file info_window_layout
                        View v = getLayoutInflater().inflate(R.layout.info_window_layout, null);
                        // Getting the position from the marker
                        LatLng latLng = arg0.getPosition();
                        // Getting reference to the TextView to set latitude
                        TextView tvLat = (TextView) v.findViewById(R.id.tv_lat);
                        // Getting reference to the TextView to set longitude
                        TextView tvLng = (TextView) v.findViewById(R.id.tv_lng);
                        double lat;
                        double lng;
                        lat =Double.parseDouble(new DecimalFormat("##.########").format(latLng.latitude));
                        lng =Double.parseDouble(new DecimalFormat("##.########").format(latLng.longitude));
                        dataBase = DatabaseHelper.instance(lat,lng);
                        // Setting the latitude
                        tvLat.setText("Latitude:" + lat);
                        // Setting the longitude
                        tvLng.setText("Longitude:"+ lng);
                        // Returning the view containing InfoWindow contents
                        return v;
                // Clears the previously touched position
                googleMap.clear();
                // Animating to the touched position
                googleMap.animateCamera(CameraUpdateFactory.newLatLng(latLng));
                // Placing a marker on the touched position
                googleMap.addMarker(markerOptions);
         double latitude = 17.385044;
        double longitude = 78.486671;
    private void initilizeMap() {
        if (googleMap == null) {
            googleMap = ((MapFragment) getFragmentManager().findFragmentById(
                    R.id.map)).getMap();
            // check if map is created successfully or not
                Toast.makeText(getApplicationContext(),
                        "Sorry! unable to create maps", Toast.LENGTH_SHORT)
                        .show();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        int id = item.getItemId();
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
ApplicationContentProvider.java
Code:
import android.app.Application;
import android.content.Context;
public class ApplicationContextProvider extends Application {
     * Keeps a reference of the application context
    private static Context sContext;
    @Override
    public void onCreate() {
        super.onCreate();
        sContext = getApplicationContext();
     * Returns the application context
     * @return application context
    public static Context getContext() {
        return sContext;
DatabaseHelper.java
Code:
import android.content.ContentValues;
import android.database.Cursor;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteException;
import android.database.sqlite.SQLiteOpenHelper;
import java.io.File;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
public class DatabaseHelper extends SQLiteOpenHelper {
    SQLiteDatabase mDataBase;
    static double latitude;
    static double longitude;
    int count;
    // The Android's default system path of your application database.
    //data/data/ and /databases remain the same always. The one that must be changed is com.example which represents
    //the MAIN package of your project
    private static String DB_PATH = "/data/data/com.mymap.www/databases/";
    //the name of your database
    private static String DB_NAME = "database.db";
    private static final String SQLITE_TABLE = "data91";
    private static final String TAG = "ConcentrationDbAdapter";
    private static DatabaseHelper sInstance = null;
    // database version
    private static final int DATABASE_VERSION = 1;
     * Constructor Takes and keeps a reference of the passed context in order to
     * access to the application assets and resources.
    private DatabaseHelper() {
        super(ApplicationContextProvider.getContext(), DB_PATH + DB_NAME, null, DATABASE_VERSION);
        try{
            createDataBase();
        catch (IOException e){
            throw new Error("Error copying database");
        try {
            createDataBase();
            openDataBase();
        } catch (IOException e) {
     * Singleton for DataBase
     * @return singleton instance
    public static DatabaseHelper instance(double lat, double lng) {
        latitude = lat;
        longitude = lng;
        if (sInstance == null) {
            sInstance = new DatabaseHelper();
        return sInstance;
     * Creates a empty database on the system and rewrites it with your own
     * database.
     * @throws java.io.IOException io exception
    private void createDataBase() throws IOException {
        boolean dbExist = checkDataBase();
        if (dbExist) {
            // do nothing - database already exist
        } else {
            // By calling this method an empty database will be created into
            // the default system path
            // of your application so we are gonna be able to overwrite that
            // database with our database.
            this.getReadableDatabase();
            try {
                copyDataBase();
     * Check if the database already exist to avoid re-copying the file each
     * time you open the application.
     * @return true if it exists, false if it doesn't
    private boolean checkDataBase() {
        SQLiteDatabase checkDB = null;
        try {
            String myPath = DB_PATH + DB_NAME;
            checkDB = SQLiteDatabase.openDatabase(myPath, null,
                    SQLiteDatabase.OPEN_READONLY);
        } catch (SQLiteException e) {
            // database doesn't exist yet.
            throw new Error("database doesn't exist yet");
        if (checkDB != null) {
            checkDB.close();
        return checkDB != null;
     * Copies your database from your local assets-folder to the just created
     * empty database in the system folder, from where it can be accessed and
     * handled. This is done by transfering bytestream.
    public void copyDataBase() throws IOException {
        // Open your local db as the input stream
        InputStream myInput = ApplicationContextProvider.getContext().getAssets().open(DB_NAME);
        // Path to the just created empty db
        String outFileName = DB_PATH + DB_NAME;
        // Open the empty db as the output stream
        OutputStream myOutput = new FileOutputStream(outFileName);
        // transfer bytes from the inputfile to the outputfile
        byte[] buffer = new byte[1024];
        int length;
        while ((length = myInput.read(buffer)) > 0) {
            myOutput.write(buffer, 0, length);
        // Close the streams
        myOutput.flush();
        myOutput.close();
        myInput.close();
    private void openDataBase() throws SQLException {
        // Open the database
        mDataBase = SQLiteDatabase.openDatabase(myPath, null,
                SQLiteDatabase.OPEN_READWRITE);
     * Select method
     * @param query select query
     * @return - Cursor with the results
     * @throws android.database.SQLException sql exception
    public Cursor select(String query) throws SQLException {
        return mDataBase.rawQuery(query, null);
     * Insert method
     * @param table  - name of the table
     * @param values values to insert
    public void insert(String table, ContentValues values) throws SQLException {
        mDataBase.insert(table, null, values);
     * Delete method
     * @param table - table name
     * @param where WHERE clause, if pass null, all the rows will be deleted
    public void delete(String table, String where) throws SQLException {
        mDataBase.delete(table, where, null);
     * Update method
     * @param values - values to update
     * @param where  - WHERE clause, if pass null, all rows will be updated
    public void update(String table, ContentValues values, String where) {
        mDataBase.update(table, values, where, null);
     * Let you make a raw query
     * @param command - the sql comand you want to run
    public void sqlCommand(String command) {
        mDataBase.execSQL(command);
    @Override
    public synchronized void close() {
        if (mDataBase != null)
            mDataBase.close();
        super.close();
    @Override
    public void onCreate(SQLiteDatabase db) {
    @Override
    public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
activity_main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent" >
    <fragment
        android:id="@+id/map"
        android:name="com.google.android.gms.maps.MapFragment"
        android:layout_height="match_parent"/>
</RelativeLayout>
info_window_layout.xml
Code:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="wrap_content"
    android:layout_height="wrap_content"
    android:orientation="vertical" >
    <TextView
        android:id="@+id/tv_lat"
        android:layout_height="wrap_content" />
    <TextView
        android:id="@+id/tv_lng"
    <TextView
        android:id="@+id/tv_date"
    <TextView
        android:id="@+id/tv_co"
    <TextView
        android:id="@+id/tv_no2"
    <TextView
        android:id="@+id/tv_no"
    <TextView
        android:id="@+id/tv_nox"
    <TextView
        android:id="@+id/tv_o3"
    <TextView
        android:id="@+id/tv_pm10"
    <TextView
        android:id="@+id/tv_pm2_5"
    <TextView
        android:id="@+id/tv_so2"
    <TextView
        android:id="@+id/tv_aqi"
    <TextView
        android:id="@+id/tv_status"
</LinearLayout>
AndroidManifest.xml
Code:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.airpollutionmap.www"
    android:versionCode="1"
    android:versionName="1.0" >
    <uses-sdk
        android:minSdkVersion="11"
        android:targetSdkVersion="21" />
    <uses-permission android:name="android.permission.INTERNET"/>
    <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
    <!-- The following two permissions are not required to use
         Google Maps Android API v2, but are recommended. -->
    <uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
    <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
    <uses-permission android:name="com.mymap.www.permission.MAPS_RECEIVE" />
    <uses-feature
        android:glEsVersion="0x00020000"
        android:required="true"/>
    <application
        android:allowBackup="true"
        android:icon="@drawable/ic_launcher"
        android:label="@string/app_name"
        android:theme="@style/AppTheme" >
        <meta-data
            android:name="com.google.android.geo.API_KEY"
            android:value="AIzaSyC1BF_BwuWL_iiXx6VCXF6zDFEJk9_U33g"/>
        <meta-data
            android:name="com.google.android.gms.version"
            android:value="@integer/google_play_services_version" />
        <activity
            android:name=".MainActivity"
            android:label="@string/app_name" >
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
