Apps Problem with EditText
Fischer
Hello everybody I am now beginning to tinker with Android, and I have a problem that is much more simple could not understand why this happening, so come to this problem: The thing is I'm trying to create a text field, but what happens is that I can not visualize it in the emulator and did not understand why because I think it has nothing wrong.
I will show you the code below:
main.xml
Code:
[FONT=monospace][COLOR=#009900][COLOR=#3F7F7F]<?xml[/COLOR] [COLOR=#7F007F]version[/COLOR]=[COLOR=#2A00FF]"1.0"[/COLOR] [COLOR=#7F007F]encoding[/COLOR]=[COLOR=#2A00FF]"UTF-8"[/COLOR][COLOR=#ddbb00]?>[/COLOR][/COLOR]
[COLOR=#009900][COLOR=#3F7F7F]<LinearLayout[/COLOR] [COLOR=#7F007F]xmlns:android[/COLOR]=[COLOR=#2A00FF]"http://schemas.android.com/apk/res/android"[/COLOR]
    [COLOR=#7F007F]android:orientation[/COLOR]=[COLOR=#2A00FF]"vertical"[/COLOR]
    [COLOR=#7F007F]android:layout_width[/COLOR]=[COLOR=#2A00FF]"fill_parent"[/COLOR]
    [COLOR=#7F007F]android:layout_height[/COLOR]=[COLOR=#2A00FF]"fill_parent"[/COLOR][COLOR=#ddbb00]>[/COLOR][/COLOR]"
    [COLOR=#009900][COLOR=#3F7F7F]<EditText[/COLOR]
    [COLOR=#7F007F]android:layout_height[/COLOR]=[COLOR=#2A00FF]"wrap_content"[/COLOR]
    [COLOR=#7F007F]android:hint[/COLOR]=[COLOR=#2A00FF]"@string/cptext"[/COLOR][COLOR=#ddbb00]/>[/COLOR][/COLOR]
[COLOR=#009900][COLOR=#3F7F7F]</LinearLayout[COLOR=#ddbb00]>[/COLOR][/COLOR][/COLOR][/FONT]
strings.xml
Code:
[COLOR=#009900][COLOR=#3F7F7F]<resources[COLOR=#ddbb00]>[/COLOR][/COLOR][/COLOR]
    [COLOR=#009900][COLOR=#3F7F7F]<string[/COLOR] [COLOR=#7F007F]name[/COLOR]=[COLOR=#2A00FF]"app_name"[/COLOR][COLOR=#ddbb00]>[/COLOR][/COLOR]HelloAndroid[COLOR=#009900][COLOR=#3F7F7F]</string[COLOR=#ddbb00]>[/COLOR][/COLOR][/COLOR]
    [COLOR=#009900][COLOR=#3F7F7F]<string[/COLOR] [COLOR=#7F007F]name[/COLOR]=[COLOR=#2A00FF]"cptexto"[/COLOR][COLOR=#ddbb00]>[/COLOR][/COLOR]Digite o Texto[COLOR=#009900][COLOR=#3F7F7F]</string[COLOR=#ddbb00]>[/COLOR][/COLOR][/COLOR]
[COLOR=#009900][COLOR=#3F7F7F]</resources[COLOR=#ddbb00]>[/COLOR][/COLOR][/COLOR][/FONT]
I hope you can help me. I await answers.
If that is code snapped directly from your code, you are either missing an "o" or having an unwanted "o" in the string resource named cptext(o)...
