androidnewbie12
Hello..
I have a POCO phone F2 Pro and I need to be able to connect through ethernet and set Static Ip for ethernet connection..
I am using a usb c to ethernet adapter. WHen i plug in the ethernet cable on the adapter I have internet without problems out of the box.. I didn't need to do anything as it worked directly..
The problem is that once i connect the ethernet cable to my phone, I don't see any ethernet option in the settings menu of the phone.. I have searched all over the phone settings, i have enabled developer options but nothing...
Please could someone help me on this ? How can i make the ethernet option appear on the settings menu so that I can then set static Ip on the ethernet connection???
THanks a lot..
THanks a lot..
