problem with gmail in android
shmu1974
Hello
I have a problem ,i have note 2
When someone send me a email l get it twice
Once in my gmail app and then to the android mail app
I tried several things with any succeed
What can i do? l want to get it only to my gmail app
Thanks
Hello
Thanks
You should just have to remove your account info from the android mail app. Should be able to do it from within the app itself, or going into menu>settings>apps, find the mail app and clear the data. You will also find others with your device here:
http://androidforums.com/samsung-galaxy-note-2/
(I can also move this thread there if you like)
They would be able to assist you with more specific instructions.
Thanks for joining the forums:D hope to see you around
